Crown picker hard plug 1 direction
Hello
Have a crown picker hard plug 1 way
Also hard braking in same direction
Puf forward
No codes
Battery good ,no leaks to frame.
Replaced access controller
Set all parameters and calibration with service terminal
Any ideas greatly appreciated.
Only happens with steering straight
  • Posted 6 Jun 2019 08:46
  • By Pistolpeted
  • joined 15 Dec'18 - 34 messages
  • Connecticut, United States
Sounds like you need a steer bearing. Not the easiest job to do. You have to drop the drive unit and remove the drive motor. 2 holes where the drive motor is mounted, knock the bearing down and out.
  • Posted 13 Jun 2019 23:06
  • By Ifixit
Giant dragonfly-like insects existed before dinosaurs and were known as "griffinflies". They lived around 317-247 million years ago and had wingspans of up to 71 cm (28 in).
May 14, 2026 - Blair Athol, South Australia, Australia
