Crown PE4500:
crown pe4500
what is a code 21
  • Posted 11 May 2016 01:00
  • Discussion started by kelly_p
kelly j. polk
Thats a common code for the old 2 wire pot... if its a 4500 series the code will be 336.... do your self a favor and upgrade to 3 wire pot if the control can be changed to type 2 pot kit # is 137027
  • Posted 25 May 2016 05:53
  • Reply by irrk1
You sure that's not a PE 4000 all 4500 codes are 3 numbers. If its a 4000 then the throttle wiper input fault. Check the voltage at pin 16 at the controller CA404 leave the handle up the voltage should be about 4.4 and then turn the handle (twist grip) it should smoothly go to about 0.2 in each direction. Adjust the pot as needed or replace. If your not getting voltage it's usually a broke wire in the handle harness where it bends when the handle is lowered.
If this is a 4500 then the display should not be showing a 2 number code always 3 numbers. If you power the truck up and the display goes out then take a hammer and tap on the lift pump solenoid this is usually a stuck solenoid. Then rekey it if that works then replace it.
Report back with where your actually getting this code from.
  • Posted 12 May 2016 08:38
  • Modified 12 May 2016 08:52 by poster
  • Reply by Zerk
  • Arkansas, United States
Hangcha CBD15
China
USD1,600
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Zhejiang UN Forklift Co., Ltd
TCM FD115-3
Hoist Liftruck F180-36BOX-CAR
Linda Häkkilä Linda Häkkilä
