Crown Pallet Jack 3035-45
I recently purchased a used Crown pallet jack WP3035-45 it worked fine for about a week then the code BD1 kept appearing even though I'd leave it charging overnight and would randomly not want to move only in one direction. I opened it up and it had Costco batteries not the Vforce so I'm assuming the guy changed them for those since they're cheaper. Could that be the issue? He said they're new and they have a sticker of 6/25 so I'm assuming he's telling the truth. No other codes show so I'm wondering if I should just buy new batteries for it. Help point me in the right direction please Crown doesn't really help even with the $300 to speak with a tech
  • Posted 13 Nov 2025 03:20
  • By Manuel_Jr
  • joined 13 Nov'25 - 3 messages
  • Utah, United States
Also bad travel potentiometer will cause your issue. You have to take control pod at top of handle completely apart to replace it. It will take several small to medium size torx bits or screw drivers to get to it. 4 screws holding handle in tiller, thumb wheel screws, two holding up or down button in place and two at bottom. The pot is in between the thumb wheels, not sure of cost. I can change one out in 20 minutes but I have changed quite a few lol
  • Posted 15 Nov 2025 06:04
  • By Stoney
  • joined 15 Nov'25 - 3 messages
  • Fl/Ga, United States
Stoney
Pull the knuckle cover off,sounds like you have a partially broken wire in Harness or the two switches on either side brk and override have a broken wire or not adjusted properly, could also be worn tiller shaft bushings causing those two switches not to function correctly. Do you have side to side play in handle aka tiller? Those two bushings being worn will cause the brake and override switches not to actuate properly. You can bend the lil actuator arms to get it working correctly
  • Posted 15 Nov 2025 05:57
  • By Stoney
Stoney
Typically if you are having issues traveling in one direction a fix would be to calibrate the directional pot and switches, but you need a curtis handset to be able to do this. Crown will have this handset.
I tend to try never to rule out batteries without testing them even if they are brand new. Recently there has been a large ammount of batteries that die a few months after installation no matter the brand. I'm not sure why the quality recenty dropped off the last few years but I have had to complete a lot more warranty claims over the last 2 years.
From my memory I think costco batteries are rebranded Interstate Batteries, which are not my favorite battery brand.
Best of luck, let me know if you have any questions. I work on alot of these pallet jacks.
  • Posted 13 Nov 2025 23:15
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 226 messages
  • Wisconsin, United States
Do you have any suggestions on how I can start to find the problem if it isn't the batteries since it doesn't show a code? It will run perfectly pushing even loaded but once I try to pull it'll make a click sound & stop then not go any direction until turn it off and on then it'll push again however it won't pull even not loaded
  • Posted 13 Nov 2025 23:13
  • By Manuel_Jr
Thank you I appreciate the info, I'll do that. Th batteries are brand new so I highly doubt it's that.
  • Posted 13 Nov 2025 23:11
  • Modified 13 Nov 2025 23:15 by poster
  • By Manuel_Jr
The BDI "code" you are seeing stands for Battery Display Indicator. This is normal and should appear normally. The number displayed after the BDI message indicates the battery percentage.
If it doesn't want to move in one direction it most likely has to do with the handle and not the batteries. The best way to test the batteries is to place your dvom leads into the main positive and negative cables. You should see a voltage of >24v. Then while watching that value, lift the forks fully and see how far the voltage drops. If it drops more than 15% then most likely one or more of the batteries is dead.
Otherwise to solve the issue you will have to dive deeper into the issue to find the cause.
  • Posted 13 Nov 2025 22:28
Anneli Karkovirta Anneli Karkovirta
Executive vice president, people & culture, Konecranes
Manager - warehouse solutions and motive power, Briggs Industrial Solutions
Vice-chair, ALICE - (Alliance for Logistics Innovation through Collaboration in Europe)
Co-CEO, LIS Logistische Informationssysteme (LIS)
Unicarriers FHGE35T5S
Morooka MFD20
November 10-12, 2026 - Marina Bay Sands, Singapore
November 25-26, 2026 - Budapest, Hungary
November 25-27, 2026 - Jakarta, Indonesia
