crown 15mt won't move forward or backwards
relays click but no movment
  • Posted 11 Oct 2017 07:46
  • By glbeacher
  • joined 11 Oct'17 - 3 messages
Opposite side of the drive motor, also check the motor brushes....could be worn out or stuck in the holders.
  • Posted 16 Oct 2017 03:34
  • Modified 16 Oct 2017 03:39 by poster
  • By Ifixit
yes it was passing through the contacts.
now I don't know where this brake switch is. only the door switch, which I bypassed. so I don't know if the brake switch works or not.
where is it located.
thanks for replying.
  • Posted 16 Oct 2017 03:19
  • By glbeacher
That's just so the door doesn't swing and knock you over, lol. There is also a little brake switch down there. It could "click", but does it work? Also, is the voltage passing through the contactors after they close? <- another reason to have the wheel off of the ground
  • Posted 16 Oct 2017 02:50
  • Modified 16 Oct 2017 02:55 by poster
  • By Ifixit
thanks for replying. yes opened up the door and can see all 3 click for each direction. already checked the fuse, and voltage to the drive motor. batteries are brand new. I did bypass the door switch.
I didn't raise the drive tire off the ground. Don't know what else to check. the drive motor has four main terminals. two of them seem to be grounds, and 2 of them have 12volts on each. why raise the drive tire off of the ground?
thanks again
  • Posted 14 Oct 2017 00:37
  • By glbeacher
This is an easy system. So, you hear 3 contactors "click" in each direction? Check the power fuse first, then check for mechanical binding in the contactors. Next, open door and raise drive tire off of the ground. Bypass the door switch and check for battery volts to the drive motor.
  • Posted 13 Oct 2017 10:30
  • By Ifixit
Michel Denis Michel Denis
Terberg YT222
Crown WP302020
