Cranks but will not start
I have a Toyota 8FGU25 forklift that cranks but will not start. I have replaced the entire fuel system and nothing. I have noticed that the idle solenoid is not working when cranking the engine. We tested the solenoid on another forklift and it works just fine. There is power, good ground. We removed the harness for the fuel system and checked for broken wires and continuity and everything checks out ok. Has anyone had this problem before, if so could you all help me out.
  • Posted 1 Aug 2024 00:47
  • By Hemi
  • joined 9 Aug'22 - 13 messages
  • New Mexico, United States
Humberto Fernandez
Good job!
  • Posted 6 Aug 2024 02:29
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
Good morning Mathew and thank you for your input. I figured out the problem. It was a ground issue, the ground wire that supplies ground to the idle solenoid was broken inside the wire harness. I repaired it and test. Forklift started with no issues. Hopefully this will work for someone else with the same problem.
  • Posted 5 Aug 2024 23:04
  • By Hemi
Humberto Fernandez
Do you have spark? If so pull distributor cap and check that there is no moisture inside
  • Posted 3 Aug 2024 14:05
  • By Matthew_Reed
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
