Continental F163 confusion
My donor engine (possibly 1978 V40B Caterpillar ) I need a model and serial# to order parts. I spent countless hours google searching what little information I have now, it has a downdraft carburetor, muffler beside valve inspection plate, Cat pn#CT7N1086 crankcase breather, prestolite IDJ 4012 distributor with sensor and external ignition module ( holley gold box) any and all help would be greatly appreciated
  • Posted 13 Feb 2016 16:10
  • By HYTECH
  • joined 10 Apr'14 - 24 messages
  • Virginia, United States
Thanks MRFIXIT for supplying me with the S/N that I needed, I contacted the Cat dealer , they sent me parts breakdown I needed to conform everything was same and they will get me all the parts needed. Also thanks to everyone else for input.
  • Posted 16 Feb 2016 16:12
  • By HYTECH
Here we go again
So much time cleaning the engine of who knows what. Just to locate where the tag used to be. Its a good thing im doing this on my own time and not my bosses, he'd rip me a new one. Is it possible to post a pic on here
[email address removed]
  • Posted 16 Feb 2016 12:42
  • By HYTECH
Unfortunately Continental did not stamp the spec or serial # anywhere on their engines so if the plate is missing ther is no way to correctly identify it.
  • Posted 16 Feb 2016 12:20
  • By duodeluxe
  • United States
Block Cast#F400A-612
Head C/N#F401A-602
Blk#243907 F1 008 6279
Date 9-30-77.
Intake#F400E-423
Exhaust #RED SEAL.
DipstickV F400L-4230
Water neckF400K-380.
Wtr pumpF600K-520
Distributor# Prestolite IDJ 4012 10c crab style dist cap solid state breakerless trigger sensor (pn#YT76000283) with externally mounted ignition module (GE engine regulator/gold box)
It seems every tractor, generator, welder forklift etc.was powered by one of these back before my time. After searching nonstop the 1977 Caterpillar V40B 79M2205 or 79M4199 and Cat T50B 14N1463 or 14N3262 are the closest cosidering the crankcase breather, distributor, top flow downdraft carburetor , bottom mount muffler, governor to carburetor rods,linkages and pivots. Sorry for TMI
  • Posted 16 Feb 2016 11:15
  • By HYTECH
If you have the spec# or serial # of the engine you should be able to get the correct parts and find out what it came out of.
  • Posted 14 Feb 2016 23:32
  • By duodeluxe
  • United States
duodeluxe
I will do a search with that s#, TVH doesnt show any pics of the gov rods and says they are dealer only item, If could get measurements and dimensions of that "L" shaped pivot ,fabricating it would be easy. All the flaheads I have checked in lifts, tractors and generators use updraft carbs with different setups.
  • Posted 14 Feb 2016 01:44
  • By HYTECH
You could try model V40B serial #79M followed by a number around 2000, like 79M2205. The linkage rods from the petal back may be tricky to figure out but the pivot on the manifold should be all the same. The muffler is probably a 333159 if it bolts on right to the exhaust manifold. If you have a Cat dealer nearby ask them if they have a paper parts book you could take a look at for V40B with Continental motor. My local dealer has a huge library that comes in handy for old machines.
  • Posted 13 Feb 2016 23:52
I talked to the huge forklift graveyard in Cali, sent multiple pictures to them ,but they insisted they need a Cat Mdl# and S#.
  • Posted 13 Feb 2016 17:28
  • By HYTECH
The governor linkage rods , L shaped pivoter mounted on intake manifold to linkage rods to carburetor , linkages from acceleration pedal to governor. Muffler assy, air horn assy. I bought a 1979 Ford CL40 skidsteer with this engine already in it, the owner couldnt get it running soi bought it. He said the engine was from either an Allis, Clark, Yale, Hyster , or Cat. So after searching imo it resembles the Cat v40b. Thanks for the speedy response
  • Posted 13 Feb 2016 17:04
  • By HYTECH
Here we go again
What parts you looking for for this? Engine parts? If you know it is a continental F163....you can get them thru any NAPA store or even online as it is a pretty basic and was widely used in other applications besides early forklifts.
  • Posted 13 Feb 2016 16:16
  • By kevin_t
Unicarriers FD80-2
Taylor T650L
