Come out of gear. Forward or reverse.
Hi, I recently purchased a CY50 serial number Y50B-134-2085. The motor runs great but the lift comes out of gear when its challenged. A small rock will prevent the machine from moving. Its full of ATF and i don't smell clutch burning, but its acting like it. Please help, Im new to these forklifts and not sure what to look for.
Thanks
  • Posted 17 Nov 2016 08:55
  • By AKmike
  • joined 17 Nov'16 - 3 messages
  • Alaska, United States
No change. Machine still comes out of gear if it goes up a small hill or even climbs through a small pot hole.
  • Posted 22 Apr 2020 01:53
  • By AKmike
It is also common that the springs in the slave cylinder break and will not let the arm attached to the salve retract and engage the transmission.
  • Posted 18 Nov 2016 22:55
  • Modified 18 Nov 2016 22:56 by poster
Ok, Ill check it out.
  • Posted 18 Nov 2016 09:31
  • By AKmike
Check the left master cylinder to see if there is free travel. On top of the trans control cover there should be a cylinder housing with a brake line going to it. That is the inching slave, make sure there is zero pressure on this with the left pedal all the way up.
  • Posted 17 Nov 2016 09:59
  • By BREWSKI
Maxlion MTF25-60-2WD
Terberg YT222
Combilift Ltd
Combilift Ltd
