codes Pin27 S/C vrbb Pin 065
i have this lift. clark. C25CL C232L-0352-9864KB mazda type engine.
1. problems starting. running rough when started. would die when accelerated.
service--
1. cleaned ca50 card and electronic throttle assembly. customer replaced regulator.
2. started a little easier. still same issue.
3. checked all wiring at throttle body. seems good. cleaned all plugs around.
4. was told that these sometimes had an issue with the throttlebody. swapped that out with another unit. same issue.
5. tried the throttle sensor assembly figuring it could be off. same issue.
6. swapped ecm and same issue.
7. customer stated he replaced plugs and wires. wen to check cap and found coil wire corroded in cap. swapped cap and rotor as well as wires. started up and smoothed out and idled for 10 minutes. perfect.
8. go to accelerate and she will die within 5 seconds.
9. has two black vacuum valves by the throttle body which i figure are trim valves also. did not mess with them.
any ideas or help greatly appreciated.
  • Posted 20 Aug 2016 05:46
  • By lance_s
  • joined 20 Aug'16 - 1 message
Hang tough or go home
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
Ncn 110TH
Ncn 110TH 2015
Tusk 350CGH20
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
