codes 34 and 61
i have a cat e6000 and it is showing codes 34 and 61 any idea on what these codes are would help a lot. The truck will not drive or lift.
Thanks
Jordan
  • Posted 26 Aug 2014 07:40
  • By jordan_b
  • joined 26 Aug'14 - 4 messages
strange nobody has answered this one yet
code 34 is Pump Motor current sensor fault
possible DSP card fault or ribbon cable connection problem.
worse case the inverter is bad.
code 61 is group 3 not set correctly.
if you are getting both these codes the problem is usually set by code 34 and code 61 is a symptom code because of code 34.
check the pump inverter very closely, check the power terminals for any melting.
According to the service grams on these codes they point to a faulty pump inverter.
  • Posted 1 Sep 2014 01:44
Columbia, SC, United States
Saratoga, United States
East Syracuse, United States
Hawker Powersource, Inc.
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
Terberg RT403
UN Forklift FGL35T
CEO, MHEDA
