Linde (& Baker) E30P:
CODE T334
Hi folks, i have an electric forklift that we just did a differential service and PM service. After the repairs were complete the technician went to drive the unit and code T334 is flashing as soon as the unit is put in gear, we do not have any service info on linde. Can anyone help?
  • Posted 21 Jun 2014 02:36
  • Discussion started by AndrewP
  • Alberta, Canada
SELL THE BEST, SERVICE THE REST!
Great experience all ready show error code T334 i follow all stapes problem solve actully emergency stop swich foulty. Thanks for share your voluble experience thanks once again
  • Posted 9 Jul 2021 02:41
  • Reply by shahid_s
  • India
sscshaikh
If you are working on a BR 387 this may help.
Fault T 334
Description:
Capacitor voltage (:A14) is too low at power module 2A1 with activated main contactor
Conditions of occurrence:
Difference between battery voltage at pin :K1 and capacitor voltage at pin :A14 >4 V
Result:
Error lamp is lit in the display unit
Truck is completely deenergized
Possible causes:
Contact resistance at the fuses 2F6, 2F1 and F2
Possible defect of fuses 2F6, 2F1 and F2
Line interruption at the output (:A15, :A30) for main contactor control
Supply voltage at pin :K1 is too low (main contactor is not energized)
Main contactor K1 is defective
Power module 2A1 is defective
Emergency stop 7S1 is defective
Key switch S1 is defective
Fan 9M2 or 9M3 is defective
Contact resistance at the lines or plugs of the a.m. components
Steps to eliminate the fault:
Check fuses
Check cable harness and connectors and replace them, if necessary
Check the function of the main contactor and replace it, if necessary
Check power module and replace it, if necessary
Check emergency stop 7S1 and replace it, it necessary
Check key switch S1 and replace it, if necessary
Check fan 9M2 or 9M3 and replace it, if necessary
  • Posted 28 Jun 2014 03:15
  • Reply by IFD45
  • Wisconsin, United States
Hi,
The serial No would be usefull.
  • Posted 27 Jun 2014 00:10
  • Reply by Karait
  • Poland
I know your deepest secret fear...
J.M.
edition #1234 - 12 June 2025
Jefferson, WI, United States
St. Louis, MO, United States
Johnston, IA, United States
