Code p04,fo4
I have a mcugl02f36lv it cranks but not starting,I'm getting fuel and spark code fo4 and p04 displays on dash
  • Posted 15 May 2018 20:37
  • By roc109
  • joined 2 Nov'09 - 51 messages
I checked all the wiring from ecm to relay box and relays and it is not a problem. I just checked the green line of the white line coming from the ecu and it does not bring any voltage or signal to the relay box to activate the relays.
  • Posted 1 Feb 2021 02:39
  • By Afshin_Ghafoori
  • joined 1 Feb'21 - 5 messages
  • Iran, Islamic Republic Of
What's a bonnet switch,I replaced the key switch,swapped dash cluster.unit cranks and run for about a sec,
  • Posted 16 May 2018 10:12
  • By roc109
Communication error check the bonnet switch
  • Posted 15 May 2018 23:19
  • By alanmitsi
  • joined 8 Aug'13 - 151 messages
  • essex, United Kingdom
Taylor TT300
USD98,500
Terberg YT220
VETTER Forks, Inc.
