code meaning
have code 524264-14 coming up after a short time of use and this code comes up and it displays transmission brake not functioning. This unit also has intermittant battery drain over night. HELP
Darren
  • Posted 19 Apr 2012 07:38
  • By darren
  • joined 29 Apr'09 - 14 messages
  • Manitoba, Canada
Go through the DSC to Calibrations. With trans. at OT, apply the brakes and the park brake, at full throttle, it will count down on its own
  • Posted 10 May 2012 22:34
  • By EyoungT
  • joined 9 May'12 - 5 messages
  • Maine, United States
How do i recalibrate the trans valve?
thanks for the reply.
  • Posted 10 May 2012 01:20
  • By darren
  • Manitoba, Canada
You may need to just Recalibrate Trans valve. As for drain, with Key off, hook meter between Pos cable and Post, unplug fuses until section is identified, then goto individual components.
  • Posted 9 May 2012 23:51
  • By EyoungT
Manual says it could be a tiss or toss sensor failure. Should be 5 volts between wire 256 and wire 108. Also check for shorts or broken wires, in the remaining wires to the tiss and or toss sensor.
The intermittant battery drain could be a fun one. You can isolate circuits by removing fuses or relays ubtil you find it.
  • Posted 19 Apr 2012 13:35
  • By meliftman
  • joined 31 Jan'12 - 209 messages
  • Alabama, United States
Liftman
Retired
Elberta, Al.
Deborah Baker Deborah Baker
UN Forklift FD30T-NJM1
SMV (Konecranes) 4632CC5
Muncie, IN, United States
