Toyota 8BRU18:
Code help
Hello All ,
got an 8BRU18 throwing codes 67 and 18 that has been shutting down mid lift and losing all power during transit including dead man not working when power goes (something that should not happen) and only code that will show at that time is 67..... found a split in the main harness , swapped out and 2 display boards in 2 weeks yet still getting these codes. Any ideas?
  • Posted 4 Sep 2016 19:54
  • Discussion started by manonamission
  • Illinois, United States
Code 97: Control Handle Switch Activated When Key Switch was Turned ON
make sure there are no swithches stuck on when powering on make sure control handle is in neutral
  • Posted 10 Oct 2017 11:42
  • Reply by kevin_t
Getting a code 97
  • Posted 10 Oct 2017 03:13
  • Reply by ifsmike
Code 67 - Steering Sensor Error
Software detected the three steering sensors (180° sensor,
Steer Stop A sensor and the Steer Stop B sensor) were all ON
or all OFF at the same time. This condition should not occur
during normal operation and indicates that one or more of the
sensors are inoperative, incorrectly adjusted, or the Tractor
Interface Card or wiring is a problem. There may also be
mechanical problems causing the code.
  • Posted 11 Jan 2017 13:13
  • Reply by fixnproblems
Don't have a code 67 on my list but code 18 is "Traction-Contactor Open"
  • Posted 29 Dec 2016 10:54
  • Reply by Paradoxical_Mec
  • Virginia, United States
Toyota 8FGCU25
Flesherton, Ontario, Canada
Ncn 85TH
Ncn 85TH 2017
Louisville, KY, United States
Dubuque, IA, United States
Hangcha 80XENS
Toyota 8FD35U
edition #1228 - 1 May 2025
