code G4
code G4
Hi, I have a forklift Raymond 742DR32TT model has fault code G4, Power steering does not work, the handle of direction is clear. The code appears to depress the pedal and release the brake. Could guide me about this failure? thanks
  • Posted 18 Jul 2012 08:05
  • By hector_v
  • joined 17 Nov'11 - 42 messages
  • Puebla, Mexico
Saludos
hectorvargasm@msn.com
Hola Hector,
Senor Joe is correct.
A steer card usually fails from overheating because the drive unit radial rings are worn and cause the steer motor to over amp from drag. jack up truck and measure drive unit play with a dial gauge. There should be no more than 100 thou play! Also look under at the drive unit and check for contact of the drive unit ring and drive unit. If worn, there will be contact causing grooves. the drag will overheat the steer motor and blow the steer card!!! you may require mucho pesos to fix this! When the radial rings wear, there is tremendous drag on the steering, but the driver wont feel anything...just the steer motor feels the excess force.
  • Posted 2 Aug 2012 09:13
  • By EasiTek
Thanks for the tip.
  • Posted 19 Jul 2012 00:21
  • By hector_v
  • Puebla, Mexico
Saludos
G4 is the vehicle mgr did not detect neutral pulses. Usually this is going to be a steer amp failure.
  • Posted 18 Jul 2012 22:27
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
Hitachi HX99B
Taylor THC500L
St. Louis, MO, United States
Evansville, IN, United States
Uxbridge, Canada
Daleville, IN, United States
Load Lifter LABORER-SERIES6.000LB
Flesherton, Ontario, Canada
Toyota 7FBEU20
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
Sourdough bread contains Lactobacillus reuteri, a probiotic bacteria. During pregnancy and breastfeeding, these bacteria can travel from the mother's colon to her breast tissue and be passed to the infant through breast milk. It offers various health benefits, including potential protection against breast cancer.
