Cat Lift Trucks (& Caterpillar) P6000:
code F-73
Does anyone have any insight on a code F-73 in all my literature it says it is not a code. All the surrounding codes have to do with the hydraulic valve solenoids.
  • Posted 25 Jan 2019 01:33
  • Discussion started by porklips
  • Minnesota, United States
Buenas tardes
Para el código F73
Mitsubishi Caterpillar
Pregunta
¿Solo se puede resolver con herramienta original de diagnóstico?
O hay algún otro procedimiento?
  • Posted 1 Sep 2021 05:31
  • Reply by Enrique
  • Mexico
Thanks
  • Posted 25 Jan 2019 02:11
  • Reply by porklips
strangely enough in the Tier2 mfca TC-2005 updated error code list code F-73 is listed as empty, no code designation defined.
codes F-72 and F-74 are designated as attachment 3B solenoid error and attachment solenoid leak error codes.
Now in 2009 they released another code list in MCFA document #000134-09C where it designates error code F-73 as an hour meter gap (hour meter time difference between VCM and meter panel).
The fix for this is to use the service tool and reset line #197 to zero for M/P hour-meter.
When you do this the meter panel reacquires the stored hour meter from the VCM.
  • Posted 25 Jan 2019 02:08
  • Reply by swoop223
UN Forklift FD35T-C2JB2
Hangcha CPYD70XW24B-C
Flesherton, Ontario, Canada
Dubuque, IA, United States
Louisville, KY, United States
edition #1228 - 1 May 2025
Linda Häkkilä Linda Häkkilä
