code E06-3
im working on toyota FGCU15,im getting a code of E06-3,the forklift runs but no throttle response.Does anyone knows this code means?
Thanks in advance for the help.
  • Posted 3 Apr 2018 03:00
  • By lito_c
  • joined 13 Aug'15 - 3 messages
There's an E Throttle fuse in the fuse box. Just had a customer throwing this code because that fuse was blown when they jump started the lift. If that's your problem, after you've replaced the fuse though you will need to disconnect the battery to reset the ECU - maybe it'll self clear after enough restarts, but I manually cleared it in this truck's case.
  • Posted 30 Sep 2025 23:45
  • By NavarWynn
  • joined 30 Sep'25 - 1 message
  • PA, United States
Always listen to the customer. Never listen to the customer.
What did this end up being for you? Any trouble shooting for the code?
  • Posted 21 Jul 2021 07:24
  • By Kyle_moore
  • joined 21 Jul'21 - 2 messages
  • Indiana, United States
I have the same issue. Say it's not the harness , what else could cause this ?
  • Posted 9 Sep 2020 09:32
  • By Ty_Nelson
  • joined 9 Sep'20 - 2 messages
Tynelson@service47
06-3 06-3 Blinking 4Y-ECS Throttle motor power supply circuit open abnormality
throttle motor is on the carb where the fuel goes in most likly cause is a broken wire in the engine harness above spark plug #2
  • Posted 23 Apr 2018 06:27
  • By forkguy
  • joined 25 Jul'17 - 28 messages
opps wrong thread
  • Posted 23 Apr 2018 05:53
  • Modified 23 Apr 2018 06:29 by poster
  • By forkguy
Briefs United States
Hyster
Hitachi HX64B2
Terberg YT222
Hitachi HX64B2
Terberg YT222
