Code E 01-4
"You've probably already figured out that the battery negative must be removed, pins E1 ( looking at it, 2nd column from left middle contact) must be shorted with TC (top half circle contact). Reconnect negative terminal, key on engine off and fully depress and release accelerator 5 times.
I had to adjust the idle screw after replacing both diaphragms in the air governor and replacing the filthy stone filter. Idle was very low. This hopefully takes care of your issues."
hi, can you help us. We have the same error 01-4, we decided to remove the error using the method you described above. when we opened the block, we did not find port E1, that is, there is space for the port, but the iron connector itself is missing, can you tell me how I can erase this error using another method?
loader model 02-8FGJF35 2023
  • Posted 9 Jul 2024 20:52
  • By alex_bande
  • joined 6 Feb'24 - 6 messages
  • Moldova, Republic Of
hello 2 all
i resolved
Set the fuel switch to LPG
Bridge - connect the TC and E12 pin contacts (foto)
Turn the key to the ON position
Depress the accelerator pedal 5 times
Switch off the ignition with the key for a few seconds
Remove connect-bridge
Now it should be OK.
  • Posted 9 Jul 2024 22:47
  • By alex_bande
hello 2 all
Sue Tomic Sue Tomic
Toyota 02-2TD20
SMV (Konecranes) 12-1200B
