Code A4 setting
Anybody come across code A4 on a cat NRR40?
  • Posted 30 Sep 2020 02:23
  • By Mike_McDonald
  • joined 30 Sep'20 - 2 messages
Mike McDonald
not much on this code
the code description says "This code indicates that the COP on the VFC has timed out. This code should never be detected in normal operation.
To clear it turn key off/on
if code presists the only corrective actions it lists
1 - check static strap and circuitry (make sure it has a static strap, it is touching the floor and if there is no static strap put one on it.)
2 - Use D-Cat, version 2.8 or higher to resolve code. See "supplement - Dealer/Technitian configuration program: user instructions" on page 7-3 in service manual.
3 - the vehicle manager may be bad
just a guess but chances are it's a static strap issue
  • Posted 1 Oct 2020 20:02
  • Modified 1 Oct 2020 20:03 by poster
Esie Cortez Esie Cortez
