Raymond 540OPC:
Code 8L
2008 model 5400 stock picker, throws code 8L when turning the steering to the far left, all is well when turning right. Ran test A35, passed, and the book leaves me high and dry from there. I dont see any wear on the wires, none are bunding or pulling, but the brake coil seems unusually warm. I have another truck, one serial number digit different, can I swap the VM's just to test it rather than buying one?
  • Posted 4 Aug 2011 06:27
  • Discussion started by GaryT
Thanks Joe. After swapping out botht the VM and the fuse relay card with parts from another OPC, I finally found it. One of the brake coil wires was broken but still intact, right behind the white connector towards the top. It seems that the factory got a little too happy with the zip ties and had everything under a little too much tension.
  • Posted 4 Aug 2011 22:56
  • Reply by GaryT
Check the pins at the connector as it could be a bad crimp. On the fuse relay board look to the left side. You will see what looks to be little resistors attached to the board. Check the one marked CR1. The new revised board eliminated that and put in a jumper. You might try swapping that. When CR1 fails it will give you all kinds of problems but I still lean towards the wiring.
  • Posted 4 Aug 2011 21:52
  • Reply by joe_d
Ain't nothing I can't fix but a broken heart and the break of day!
edition #1228 - 1 May 2025
Linda Häkkilä Linda Häkkilä
Taylor TT300
USD98,500
Toyota 8FG25
Louisville, KY, United States
Dubuque, IA, United States
