Code 68 - RH Traction PMT Signal in Run Mode. Hyster J40XMT2
Any one can help this code?
  • Posted 13 May 2011 08:41
  • By li_w
  • joined 16 Nov'09 - 49 messages
Thanks!
the right side controller GE IC3645SR4T404N11 burned inside.
  • Posted 14 May 2011 08:40
  • By li_w
Had this fault recently and it was a shorted controller. right hand side one was faulty but showing codes for faults for left. you have got to make sure controllers are set up as master and slave.
  • Posted 14 May 2011 05:14
  • By sean3
  • joined 14 May'11 - 46 messages
  • lancashire, United Kingdom
-Auxiliary control (slave) shutdown..
-Check auxiliary control for stored faults.
-Verify the connection between the master control
P21 and the auxiliary/slave control P10.
You could have a bad controller(slave)
  • Posted 14 May 2011 02:36
  • Modified 14 May 2011 02:36 by poster
  • By mike_v
  • joined 1 Jul'10 - 190 messages
  • Illinois, United States
Terberg RT223
Elwell-Parker ESI500-36
Lift Technologies Inc.
Terberg RT223
