Code 676-3 Diesel Engine glow plug problem
Mechanic said he unhooked the battery, remove battery tray to get to the fuel filter. After changing fuel filter Unit will no crank, No start Has a code on display 676-3 Glow plug problem. Can not get into dash display, Need that code too. No power to glow plug relay. Serial # D024V01983F
  • Posted 12 Apr 2012 07:47
  • By joe_o
  • joined 12 Apr'12 - 3 messages
Hi joe o,
have same problem with hyster 5-ton, after changing hidraulic tank cap, the 676-4 error appeared. Wiring from glow plug relay to vsm is good, fuses are not blow. Relay gets low voltage from vsm (aprox 8.5V - measured on relay pin and directly on output pin on vsm, so the wirings are good). Any solutions?
  • Posted 7 Mar 2015 17:59
  • By pero
  • joined 12 Nov'14 - 6 messages
  • Croatia, Croatia
If you have no power at glow plug relay... wire 240-a comes from a 60 amp fuse coming from the starter battery post. Could be blown fuse or wire issue. Wire 754-0 also positive voltage comes from the vsm. If no power there, could be broken wire between relay and vsm, could be wire loose in plug. As to the codes for dash entrance, not at liberty to disclose that information.
  • Posted 12 Apr 2012 13:14
  • By meliftman
  • joined 31 Jan'12 - 209 messages
  • Alabama, United States
Liftman
Retired
Elberta, Al.
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
SMV (Konecranes) 16-1200C
USD1
Zhejiang UN Forklift Co., Ltd
