Raymond 550-OPC30TT:
Code 64 - Very slow lifting
We just brought in a used machine and it is very slow to lift. It will code 64 if you hold it. Any thoughts from Raymond experienced folks?
  • Posted 29 Oct 2021 03:45
  • Discussion started by Dan_Selph
If any one sees this and doesn't see their solution, try this: Check your battery voltage, check the lift pump splines, and if equipped with a mini-mast check your proportional valve isn't sticking. Hope this helps!
  • Posted 6 Oct 2023 11:06
  • Reply by snack_fury
  • Tennessee, United States
chequea los switches del mastil, mira si tiene un leveler malo. si eso esta normal, cambia la tarjeta controladora CCC
  • Posted 10 Feb 2023 02:30
  • Reply by max_h
HOLA
YO TENGO EL MISMO PROBLEMA.
¿COMO LO SOLUCIONO AMIGO?
Littoral Translation
HELLO
I HAVE THE SAME PROBLEM.
HOW DO I FIX IT FRIEND?
  • Posted 29 Jul 2022 01:51
  • Modified 29 Jul 2022 15:00 by administrator
  • Reply by almacenes
  • El Salvador
titoooliva
Your Focus
edition #1234 - 12 June 2025
Johnston, IA, United States
Jefferson, WI, United States
St. Louis, MO, United States
