code 6 Stepping motor is not correct
anyone have a full service manual to see how to actually troubleshoot this code? i have a full code list but it doesn't really explain what to do it states "close throttle valve fully,back to normal operation after restarting." could be a calibration issue ? need more info then whats been provided so far. any ideas ?
  • Posted 7 May 2019 03:08
  • By keith_m
  • joined 29 Jun'09 - 57 messages
keith@kmcequipment.com
Thank you for the info. we have the diagnostic tool you have listed but the service literature is very short. i'm gonna have my tech check the throttle out real good for possible binding issues and we will go from there. i'm just not sure if the amount of service info we got from our local Cat dealer is all the info thats actually in the manual. the code list and possible causes are all on one sheet we are reading.
  • Posted 9 May 2019 00:05
  • By keith_m
it is not sensing the throttle plate opening/closing completely or is receiving an incorrect signal in comparison to the accelerator pedal position sensor based on what the ECU is expecting to see.
One thing you may want to try is to clean out the carburetor with some carb cleaner to insure the throttle plate is closing completely and not being deflected by dirt keeping it from fully closing.
One other thing you can try is to remove the cover on the motor control on the throttle and check the gear area and make sure it has lube, some throttle assy's had issues with poor lubrication and would cause the mechanism to bind creating the scenario triggering the code.
The worse case is you would have to replace the carburetor/throttle assy.
Depending on which ECU it has there is a diagnostic tester you can obtain from cat part number: 9186802300 and determine the codes stored and which procedure from the service manual to perform to correctly diagnose and clear the codes and identify exactly what the problem is.
  • Posted 7 May 2019 21:27
JLG G12-55A
Terberg RT223
Bolzoni SpA (Group HQ)
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
CEO, Robust.AI
JLG G12-55A
Terberg RT223
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
