code 57
Occasionally, I get a code 57 at start up. All I have done is clean connectors with no results. Any ideas?
  • Posted 15 Feb 2012 13:32
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
If Code 57 appears when exiting Diagnostic Mode, verify that the firmware chip on the Operator Display Interface Card is at version 2005 or higher. If not, replace the Operator Display Interface Card. For chip location, see Figure 7-57 on page 7-31.
This code can occur in two ways:
* Truck operates with Code 57 displayed.
* Check continuity of wiring harness from display interface to Carriage Manager JP3-JPC18.
* If continuity is OK, replace the Operator Display Interface Card. See "Operator Display Interface Card" on page 7-81.
* Truck does not operate with Code 57 displayed.
* See "Troubleshooting Communication Fault Codes (50-series)" on page 5-20.
* Check for shorts to frame.
  • Posted 15 Jun 2025 07:44
  • Modified 18 Jun 2025 10:08 by administrator
  • By marksmith
  • joined 26 May'25 - 18 messages
  • United Kingdom
forkliftmanual.com
Hello colleagues I have this same failure change of vmc and display and still throws this error they had some solution thanks.
  • Posted 10 Jun 2025 16:26
  • By Geoanzu
  • joined 21 Sep'23 - 2 messages
  • Colombia
G&M herramientas logística s.a.s
Had another unit with a code 57. Found out someone had plugged the main mast and mini mast weight sensors in the wrong spots, they were swapped.
  • Posted 13 Oct 2018 01:07
  • By tyler_d
  • joined 23 Sep'16 - 79 messages
Is it a BIG 57 that fills the whole screen?
  • Posted 5 Oct 2018 08:53
  • By Service_T
  • joined 5 May'18 - 91 messages
  • Kansas, United States
After you go thru all the steps in the book for code 57, everything this topic has listed and if you still have a code 57 check the heartbeat at IL1 on the platform manager. If no heartbeat think about swapping out the VFC and the display card.
  • Posted 5 Oct 2018 05:26
  • By tyler_d
I agree with joe d. Just a couple more things for you. Check for shorts to frame and correct if found. The cable for the display manager sometimes breaks where it is tie wrapped to the r/s arm outter shielding may look good but ohm it out with handle up/down. Also you may just need to run a configuration download. (Key off. Depress both deadman and lift select button, key on and push lift select 3 or 4 times) when download is done code 57 will be displayed. Rekey and download is finished.
  • Posted 12 Aug 2012 02:30
  • By stam
50 series codes are information errors. The easiest thing to look at is your over mast cables. Are they starting to spiral. Ohm the cables from the tractor manager to the carriage manager and check for shorts between wires as well.
  • Posted 15 Feb 2012 23:42
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
November 10-12, 2026 - Marina Bay Sands, Singapore
September 16-18, 2026 - Guangzhou, China
edition #1301 - 1 October 2026
Forkliftaction News is excited to launch our Big Picture Interviews. In this thought-provoking series, we ask industry leaders for their insights on current market dynamics. In this week’s interview , Ralph Cox, Toyota Material Handling Europe’s SVP market operations, talks about why lean manufacturing and automation go hand-in-hand. Keep an eye out for the fortnightly interviews... Continue reading
Terberg RT223
Taylor T520S
Mohammed Kabir Mohammed Kabir
Chief executive officer, Corvus Robotics
Regional sales manager, Abbey Attachments
vice president of human resources, Big Joe Forklifts
Board of Directors, UKMHA
