code 524223-0
we have a H80ft serial F564225 in our shop. when you put it in reverse it dies and throws this code. can anybody help us out.
Code 524223-0
Doug
  • Posted 8 Jul 2010 08:02
  • By offroad72
  • joined 5 Jan'10 - 34 messages
  • Nevada, United States
Check for voltage at connector. Turn power off and unplug connector, turn power on and check for 5VDC. If not then use battery ground and test for voltage....if you get voltage then it has an open ground. Do you have technition access to the VSM....if so what does the XMSN pressures read...
  • Posted 22 Nov 2010 09:13
  • By TKOforklift
  • joined 24 Nov'07 - 30 messages
  • British Columbia, Canada
TKO Forklift and Equipment Repairs
Kamloops BC
250-819-6575
tkoforkliftservice@gmail.com
replace both direction proportional valves they work together and need replaced in pairs
  • Posted 16 Oct 2010 22:13
  • By grubbymits
  • joined 25 Jan'09 - 49 messages
  • scotland, United Kingdom
well we thought we had the forklift fixed but it is throwing the same code again. 524223-0. if anybody can shed some light on this code that would be great. I will see about getting my email on here.
Doug
offroad72.live.com
  • Posted 15 Oct 2010 02:02
  • By offroad72
Offroad, you can add your e-mail address (properly formated) in your profile.
  • Posted 10 Jul 2010 21:53
Dont use. use dot and instead of @ use at
  • Posted 10 Jul 2010 04:29
  • By 67dave67
  • joined 4 Dec'08 - 38 messages
[email address removed]
  • Posted 10 Jul 2010 04:27
  • By offroad72
my email is [email address removed]
  • Posted 10 Jul 2010 04:26
  • Modified 10 Jul 2010 04:26 by poster
  • By offroad72
you have a bad sensor, what is your email?
  • Posted 10 Jul 2010 02:48
  • By 67dave67
Enforcer FD50T-MMA
Crown SX3030TT4250
