Code 522660-0
I have a Yale GLP070VXNDAE08 that shows a code of 522660-0 and then stops running like it ran out of fuel, I found that the throttle body was going bad so I replaced it and it seems to run better but still once in awhile it will show the code 522660-0 and then stops running. it had a broken fitting on the LP regulator for the fuel going to the carb, could not get just the fitting so I had to but the hole **** regulator. It was showing this code before I found the broken fitting after changing the reg it did not run any better until I changed the throttle body. The throttle body was making a lot of clicking noise like it was shutting on and off real fast the new one does not do that but still have the code that comes up and then dies. Any help would be greatly appreciated>
  • Posted 6 Nov 2018 08:58
  • By Buddy2000
  • joined 15 Dec'17 - 41 messages
  • Illinois, United States
DTC 522660-0 - Adaptive Learning (LPG) Long Term Fuel Trim Low.
A. FUEL SYSTEM FAULT
B. EXHAUST SYSTEM FAULT
C. AIR INDUCTION SYSTEM FAULT
D. MIXER / REGULATOR FAULT
  • Posted 8 Nov 2018 00:20
  • By BREWSKI
edition #1237 - 3 July 2025
Toyota 8FBE20U
Flesherton, Ontario, Canada
Hangcha CPYD32XW71F-C
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
East Syracuse, United States
Columbia, SC, United States
Saratoga, United States
