code 479
have a repeating 479 code... manual does not give much information.. battery is ok and have tested with a known good access 4 module?.. will code upon start up with a quick keyswitch turn.. when you hold the keyswitch longer it will not code upon start up but eventually after driving it will
  • Posted 26 May 2017 02:19
  • By kyleCrown
  • joined 26 May'17 - 2 messages
These lifts have a battery negative splice for your accessories such as your strobe scanner. It'll also take out your FU5
  • Posted 3 Aug 2017 06:40
  • By Lifteck
  • joined 2 Aug'17 - 8 messages
Combilift Ltd
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
