Raymond 152OPC30TT:
Code 44
We are getting a code 44 It goes through the start up test and goes right to code 44. Any thoughts.
  • Posted 4 Feb 2010 03:10
  • Discussion started by snowman
It's your traction amplifier.
  • Posted 11 Sep 2024 23:20
  • Reply by D_Lopez
DLopez
Check across contacts with them open for voltage across them I had one that did that and although contractor was open it read voltage as if closed I found a lot of debris in contact or assembly causing to carry voltage
Enough to have control to see contacts closed
Just a suggestion
Good luck
  • Posted 16 Jul 2024 11:56
  • Modified 16 Jul 2024 11:56 by poster
  • Reply by John_Bradley
Jb69
I recently had this same issue.For me it ended up being phase W in the drive motor being shorted to the casing.
  • Posted 12 Jul 2024 11:09
  • Reply by Sean_Herrick
  • Vermont, United States
Seanherrick
Look at motor wires that run to traction amp. If motor wires feel spongy change all 3 wires.
  • Posted 17 Nov 2023 23:52
  • Reply by D_Lopez
DLopez
Just as a follow up.
Code 44 as written in the manual is contactor detected CLOSED when commanded OPEN.
Technically this means B+ is found on the PC sense wire.
eck the wire to ensure it is not shorted to B+
  • Posted 8 May 2012 10:43
  • Modified 8 May 2012 10:46 by poster
  • Reply by ForkLiftACE
ForkliftACE - Your helpline to forklift diagnostics
Twitter - @ForkLiftAce
you need to find the short to frame first.
Pull the battery and test the battery - often they have been damaged and cause the short.
Then you will need to check cable by cable, component by component. Start with the motor, check for shorts there.
Good luck
  • Posted 16 May 2010 21:34
  • Reply by JonG
  • United States
it is a 05 raymond
740-r45tt
740-05-fao2639
I have been from front to back in the manual running every test we can. The problem is that some of the test require the truck to run the drive motor and with the code 44 I cant run it. The contacters are fine. In start up it closes and then opens as it should except the brain never sees it open back up so it kicks out the code 44. It also gives a 2U code. With our volt meter we found the truck has 36 volts running throu it we we put the test lead in the neg batt cable and pos lead on the truck frame. When we unhook the drive motor we loose half those volts.
  • Posted 30 Mar 2010 20:06
  • Reply by shane_c
  • Missouri, United States
What make and model and SN?
I assume a Raymond
Code 44 is contact tips detected closed - Normally
Do you have a manual?
  • Posted 27 Mar 2010 04:29
  • Reply by JonG
  • United States
Dont mean to hijack this thread but I have a code 44 and 2U popping up at the same time. The contactor is not welded together and is working as it should in the start up test but still kicks a 44 code. The 2U code shows a current draw from somewhere but again everything looks normal. I have replaced the relay board and checked all fuses..............I am this close to rolling it out to the trash! Can anyone give me a hint as to where I can check next? Thank you very much for your time.
  • Posted 27 Mar 2010 01:35
  • Reply by shane_c
This is a common Raymond Code,
You have contactor tips welded closed
  • Posted 15 Feb 2010 12:39
  • Reply by JonG
  • United States
edition #1234 - 12 June 2025
