Code 44
We are getting a code 44 It goes through the start up test and goes right to code 44. Any thoughts.
  • Posted 4 Feb 2010 03:10
  • By snowman
  • joined 14 Sep'08 - 27 messages
It's your traction amplifier.
  • Posted 11 Sep 2024 23:20
  • By D_Lopez
  • joined 25 Apr'22 - 8 messages
DLopez
Check across contacts with them open for voltage across them I had one that did that and although contractor was open it read voltage as if closed I found a lot of debris in contact or assembly causing to carry voltage
Enough to have control to see contacts closed
Just a suggestion
Good luck
  • Posted 16 Jul 2024 11:56
  • Modified 16 Jul 2024 11:56 by poster
  • By John_Bradley
  • joined 10 Aug'22 - 304 messages
Jb69
I recently had this same issue.For me it ended up being phase W in the drive motor being shorted to the casing.
  • Posted 12 Jul 2024 11:09
  • By Sean_Herrick
  • joined 12 Jul'24 - 2 messages
  • Vermont, United States
Seanherrick
Look at motor wires that run to traction amp. If motor wires feel spongy change all 3 wires.
  • Posted 17 Nov 2023 23:52
  • By D_Lopez
DLopez
Just as a follow up.
Code 44 as written in the manual is contactor detected CLOSED when commanded OPEN.
Technically this means B+ is found on the PC sense wire.
eck the wire to ensure it is not shorted to B+
  • Posted 8 May 2012 10:43
  • Modified 8 May 2012 10:46 by poster
  • By ForkLiftACE
  • joined 8 May'12 - 8 messages
ForkliftACE - Your helpline to forklift diagnostics
Twitter - @ForkLiftAce
you need to find the short to frame first.
Pull the battery and test the battery - often they have been damaged and cause the short.
Then you will need to check cable by cable, component by component. Start with the motor, check for shorts there.
Good luck
  • Posted 16 May 2010 21:34
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
it is a 05 raymond
740-r45tt
740-05-fao2639
I have been from front to back in the manual running every test we can. The problem is that some of the test require the truck to run the drive motor and with the code 44 I cant run it. The contacters are fine. In start up it closes and then opens as it should except the brain never sees it open back up so it kicks out the code 44. It also gives a 2U code. With our volt meter we found the truck has 36 volts running throu it we we put the test lead in the neg batt cable and pos lead on the truck frame. When we unhook the drive motor we loose half those volts.
  • Posted 30 Mar 2010 20:06
  • By shane_c
  • joined 27 Mar'10 - 2 messages
  • Missouri, United States
What make and model and SN?
I assume a Raymond
Code 44 is contact tips detected closed - Normally
Do you have a manual?
  • Posted 27 Mar 2010 04:29
  • By JonG
  • United States
Dont mean to hijack this thread but I have a code 44 and 2U popping up at the same time. The contactor is not welded together and is working as it should in the start up test but still kicks a 44 code. The 2U code shows a current draw from somewhere but again everything looks normal. I have replaced the relay board and checked all fuses..............I am this close to rolling it out to the trash! Can anyone give me a hint as to where I can check next? Thank you very much for your time.
  • Posted 27 Mar 2010 01:35
  • By shane_c
This is a common Raymond Code,
You have contactor tips welded closed
  • Posted 15 Feb 2010 12:39
  • By JonG
  • United States
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
edition #1293 - 6 August 2026
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
Terberg RT223
Terberg RT223
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
Philadephia, PA, United States
Chandler, United States
