Code 43
Have a code 43. Serial # is EASI-00-AJ27055. Goes thru start up. Codes out once deadman is pressed.
  • Posted 7 Jun 2013 21:59
  • Modified 7 Jun 2013 23:58 by poster
  • By d_rad
  • joined 7 Jun'13 - 9 messages
  • Minnesota, United States
sounds like you have a bad pot in the handle giving you the un-requested lift. test A04 could help diagnose that.
your right, bad batteries are the main cause of contactor issues like you are having. code 42 is welded lift contact.
  • Posted 12 Jun 2013 20:52
  • By stam
Thanks Stam. Lost the code 43. Now have code 42. Acting real funny. If you go to drive the hydraulics kick in, and then codes out. After some hard looking I did find the TM card had a bad circuit board line. I am assuming this would be the only problem but I will find out once I get the new card and test further. I will try to keep you up to date.
By the way the battery is in pretty poor shape. I suspect that is what caused the problem. Customer continued to operate truck when it was dead.
  • Posted 11 Jun 2013 22:25
  • Modified 11 Jun 2013 22:43 by poster
  • By d_rad
code 43 is lift contactor detected open when supposed to be closed. verify it is pulling in and the fuse is good.
  • Posted 11 Jun 2013 19:55
  • By stam
