code 356
OK, I need help with this one. Turn key switch on , no codes. Step on foot switches the ED1 contactor pulls in 1 second later the contactor drops out with a 356 code. Fuses are good and have been replaced, just in case. ED1 contactor has been replaced. wiring checks good. The # 3 &4 access have been replaced with known good ones. Infopoint book stops there. What if anything am I missing? Please give me some answers.
  • Posted 22 Aug 2013 08:42
  • By rddog
  • joined 15 May'10 - 2 messages
  • New Mexico, United States
RDDOG What was the final solution for this issue? Curious what the resolution was? We're experiencing the same issue. Post back the resolution if you found it. Thanks!
  • Posted 13 Sep 2017 00:16
  • By 1JB1
  • joined 12 Sep'17 - 2 messages
  • Illinois, United States
try replacing the power fuse with known good one, as sometimes they test ok but fail under load
  • Posted 26 Aug 2013 17:44
  • By crownie
  • Victoria, Australia
Does the battery volts come back up after ED drops back out or before. IF available try another battery.
  • Posted 23 Aug 2013 22:41
  • By ctech
  • joined 29 Nov'12 - 11 messages
  • United States
Batt, it may have a reading of 36v but drops as soon as ed comes in momentarily, then reads 36v again
  • Posted 23 Aug 2013 22:28
  • By southernviking
  • joined 25 Mar'13 - 43 messages
  • South Island, New Zealand
What voltage do you get at the battery when ED pulls in?
  • Posted 22 Aug 2013 22:19
  • By ctech
  • United States
Crown CG33P5
Factory Cat MICROMAG20D
Sue Tomic Sue Tomic
