code 336
Was looking for possible description of code 336
  • Posted 2 Jun 2015 07:38
  • By manny_b
  • joined 2 Jun'15 - 2 messages
  • Arizona, United States
throttle voltage is outside limit is what this code is for. you need to check the speed pot inside the tiller handle. easiest way to do this is to go through access 1 and get into the diagnostics. you will need your manual for this. access code for level 2 is 2311 unless it has been changed by someone.
  • Posted 12 Oct 2018 02:01
  • By masterglaizer
  • joined 12 Oct'18 - 2 messages
Check your harness. Could be broken/shorted at the handle pivot point.
  • Posted 17 Feb 2018 07:26
  • By chevotaman
  • joined 28 Feb'14 - 112 messages
It's all just nuts n' bolts.
I wont be able to read any responses till monday... Its Friday and just about beer 30
  • Posted 17 Feb 2018 05:57
  • By DanMc
  • joined 8 Jun'16 - 80 messages
I've the same 336... the pot is good , both the fs and rs only show 0 (can both go bad at the same exact time ?)... The guy using it said it was fine before he parked it and went to lunch... Its only about 2 weeks old. Any ideas ?
  • Posted 17 Feb 2018 05:55
  • By DanMc
It can switch from 0 to 1, but resistance in the switch will log the 336 code every time. Make sure you look on the switch you're using, a 15a switch will perform much better than the 10a ones used from the factory. When I go to a breakdown call for a 336 code and I see switches in there with one white side....automatically change them first.
  • Posted 17 Aug 2017 11:29
  • By Ifixit
This could also mean the accell pot needs to be adjusted. Turn this only in small increments at a time. Usually a wrench light will show when this is the case.
  • Posted 7 Aug 2017 11:07
  • By jeffg95
  • joined 26 Sep'16 - 9 messages
  • Tennessee, United States
Go into Analyzer and check the status of the Fwd/Rev should as you move the twist grip. Status should change from 0 to 1 if the switches are good. If they are good than adjust the screw down so each switch closes very shortly after the twist grip is turned.
  • Posted 1 Aug 2016 07:47
  • By jeffrey_r
  • joined 23 Jul'11 - 10 messages
336 is Throttle V outside limits.
Not listed in T-shoot steps for this fault but Ive found a broken/shorted wire to the BRS on this, or a bad switch itself.
  • Posted 3 Jun 2015 02:11
  • Modified 17 Aug 2017 22:38 by poster
  • By chevotaman
SMV (Konecranes) 12-1200B
Tusk 500PGH14
Sue Tomic Sue Tomic
