Report this forum post
throttle voltage is outside limit is what this code is for. you need to check the speed pot inside the tiller handle. easiest way to do this is to go through access 1 and get into the diagnostics. you will need your manual for this. access code for level 2 is 2311 unless it has been changed by someone.
  • Posted 12 Oct 2018 02:01
  • By masterglaizer
  • joined 12 Oct'18 - 2 messages
Indicates mandatory field
Nagano NUZ090D
SMV (Konecranes) 12-1200B
