code 329
gotta fork that keeps throwing a 329 code. I can't find it in my book or any newer books i have found on line. It throws the code when leaving a isle and turning off the wire guide. has anyone run across this or is it a phantom code?
  • Posted 8 Mar 2018 00:02
  • By alf71
  • joined 7 Mar'18 - 3 messages
  • Kansas, United States
no one has come from the future to stop me yet
That is what i did. I tried from 5 ohm up to 20 ohm from the battery neg to pin 6 on connector 402 and had no luck. It actually caused another internal access code that would never clear unless the resistor was removed. Who knows things get weird.
  • Posted 31 Jul 2018 21:43
  • By alf71
You wont find it in any book. You will need to install a resistor off the main B- on acc 3. The specifics are in my previous post on this issue. 5-10 ohm resistor to the pc402-6 wire.
  • Posted 29 Jul 2018 23:52
  • Modified 29 Jul 2018 23:54 by poster
  • By PESLLC
  • joined 10 Oct'13 - 35 messages
  • fl, -
DC
thanks PES I tried several different configurations of resistors to pin 6 and had no luck and had to replace the access 3 to correct the issue
  • Posted 28 Jul 2018 02:45
  • By alf71
It's an internal access fault.
Run a jumper from the center neg lead on access 3 to pc402-6.
You will need to put a 5-10 ohm resistor in that line. The stonger the better. This will beed voltage and will correct the issue.
  • Posted 16 Mar 2018 03:43
  • Modified 17 Mar 2018 06:56 by poster
  • By PESLLC
  • fl, -
DC
VETTER Forks, Inc.
UN Forklift FD35T-C2JB2
UN Forklift FD30-35T
