Code 2F. When plugging
Easi R40TT
S/N: EZ-A-23684
36 volt
During plugging the unit trips code 2F
Yet it does not cut drive speed to the required 2mph
-Q1 & Q2 replaced
-system card replaced
-power card replaced
-learn performed
-drive motor rebuilt
-Recs tested ok
-performed tests A11 & O21 - both determined q2 and power card fault, once replaced, same fault.
Any thoughts at this point would help. Thx
  • Posted 25 Jul 2013 06:30
  • By gwmtech
  • joined 20 Nov'12 - 4 messages
  • Manitoba, Canada
FYI by leaving the 2 cables disconnected until the truck goes through self test allows the capacitors on the Q2 to charge before you hook up the power cables.
  • Posted 21 Nov 2013 08:56
  • By forktech418
  • joined 31 May'12 - 19 messages
allow me to update,
seeing the only things i replaced before code23 showed up, was the rec2 and regen(q2),
I tried the old rec2, and... code 23 is gone! everything working great, no more code 23 or 2F for that matter (when plugging),
So... looks like the rec2 diode i received with the kit is the wrong one, but happy its done!
  • Posted 21 Nov 2013 00:32
  • By GT42R
  • joined 28 Jan'11 - 36 messages
hey guys, had a similar problem with a near identical R40TT,
When plugging/slowing down with counter-throttle,
The truck would get jerky, and eventually throw a 2F code for regen, strangely enough, the speed limit would not be cut...
Anyhow,
Replaced the regen(q2) unit with a new one, as well as the rec2 diode that came with the kit,
I did as forktech418 suggested, connected the regen 3-pin connector to the power card, but the two main power leads, i left disconnected, and ran the first self-test,
I instantly got code 23, figured it was due to the the two power cables to the regen being disconnected,
Connected the two cables back on the regen, ran self-test again... still code 23!
So far I've looked over all the obvious stuff, but I am still getting code 23...
I tried hooking up the old regen(q2) unit again just now, just to check, and still have code 23...
Any input fellas?
Started with a code 2F (when plugging), and now I have a code 23 all the time...
  • Posted 21 Nov 2013 00:12
  • Modified 21 Nov 2013 00:15 by poster
  • By GT42R
When you replace a regen you should not connect the 2 power cables until after you have let the truck go through self test once.
  • Posted 5 Oct 2013 04:54
  • By forktech418
Tip. The length of the battery cables or high resistance in the regen cabling can also produce this code.
  • Posted 11 Aug 2013 20:25
  • By fisherman
  • joined 31 Mar'12 - 8 messages
Sounds like a regen fault with the symptoms and fault code. Have you checked the rest of the regen assy? Capacitor, resistor etc?
  • Posted 25 Jul 2013 14:11
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
You didn't mention it but is you're batterie ok ?
You should always replace Q1 and REC1 as a "kit".
  • Posted 25 Jul 2013 07:11
  • By ted_h
  • joined 16 Jul'13 - 2 messages
  • Quebec, Canada
Before anyone asks. Yes. I've replaced the regen card.
  • Posted 25 Jul 2013 06:33
  • By gwmtech
  • Manitoba, Canada
F. Uchiyama
F. Uchiyama
