i went ahead and removed the hidraulic pump and the motor is still overheating it pulses and turns really slow i removed it and sent it to the electric motor shop. they will let me know by tomorrow. also the temperature here is about 115 F. this time of year. thanks for your info it really helps
Thank you guys
you are right. didnt even notice the hot motor and cables. was stuck on 2-2 w/ no prefix. insomnia.
I am Assuming it's a code E2-2 - Pump motor thermo sensor abnormality
You need to Check Thermo sensor - looks like it's heating up for some reason ( low fluid, plugged filter, very hot day)
need to know what the model # is. 2-2 sounds like a pallet jack curtis code. if so,(7series) it is a simple sequence problem. check the brake switch and or handle switches. this usually happens when brake switch is on when key is activated or directional sw is on at key on.
good luck.
