Code 19 - Please Advise
We have a code 19 showing up on display and are unable to get the lift to start. We have tried replacing the ignition switch because after you toggle the key for several minutes it usually fires up. It is starting to occur more often now. We have also already cleaned and checked all of the electrical connections.
I believe the serial number is A2EC269096 but the label is scratched up so it is hard to tell exactly.
Can somebody please give me some insight as to what this code means? Thank you
  • Posted 17 Oct 2013 00:44
  • Modified 17 Oct 2013 00:45 by poster
  • By Scott22
  • joined 17 Oct'13 - 1 message
  • Illinois, United States
Display 19 means Drive shunt field transistor drain fault (low). No lift truck operation.
check your battery first
possible causes are:
Logics not programmed correctly
open drive shunt field fuse
poor wire connections
shorted T371 transistor
logics defect
good luck
  • Posted 17 Oct 2013 20:38
UN Forklift FD30T-NJM1
Toyota 8FG25
Toyota 8FG25
Sue Tomic Sue Tomic
