code 11
serial number is c814n02403f.
can somebody supply a list of codes please. Thank You
  • Posted 29 Jul 2011 06:05
  • By hallen
  • joined 29 Jul'11 - 3 messages
  • New Mexico, United States
That was the problem. Thank You Kevin K.
  • Posted 1 Aug 2011 23:58
  • By hallen
fault is at the throttle pedal. control sees a reading from the pot before the start switch is closed. give the pedal a tug up as you turn truck on is sometimes enough to get it away. also debris gets between the pedal and the start switch which causes this fault code. last option is a faulty pot under the pedal
  • Posted 30 Jul 2011 17:19
  • By kevin_k
Thank you for the quick reply. This unit has an ac drive instead of an EV100. The unit will not complete self test. Thank you
  • Posted 30 Jul 2011 02:38
  • By hallen
hallen;
The symptom you are more then not seeing is that the FWR or REV won't pick up. Items to check: 1. Look at the accelerator switch input 2. Check to see that the voltage split at TB2 to BV- is less then 60% of battery's voltage at key switch closing. (replace or adjust the accelerator switch to insure that this voltage less then the 60% of battery's voltage before closing) 3. Check for short circuit between battery positive and TB2 in the accelerator switch input circuit. (disconnect the wire from TB2 check for short circuit from wire to battery positive. The resistance needs to be greater than 4.7k ohms. )
4. Check for defective card. (disconnect wire from TB3. Measure voltage from TB3 to battery negative. You should be zero. If you are not look for a replacement card) TB terminals are the six screw terminals of the logic card.
  • Posted 29 Jul 2011 09:33
  • By MEngr
  • Missouri, United States
Advance CS7000
Illinois, United States
USD8,000
Aichi SR10C1SM
July 9-10, 2025 - Birmingham, United Kingdom
Daleville, IN, United States
Uxbridge, Canada
Evansville, IN, United States
St. Louis, MO, United States
edition #1236 - 26 June 2025
As June comes to a close, the month when our sector recognises National Forklift Safety Day , the United Kingdom’s Association of Industrial Truck Trainers (AITT) has issued a timely reminder of the need to ensure any staff training is fully accredited... Continue reading
