Coast and rabbit button
Some of my PE4500 has a switch for the coast and once the switch is flipped on the rabbit button is supposed to not work. However, even though the coast is activated, the rabbit button still works. Is this a simple fix to make it so that once the coast switch is flipped on it shuts the function of using the rabbit button off?
Also, does anyone know how this problem would have occurred. It's happened to 3 of my PE4500 out of a total of about 60.
  • Posted 28 Nov 2017 20:14
  • Modified 28 Nov 2017 20:47 by poster
  • By Royal
  • joined 28 Nov'17 - 1 message
you can go into service menu and check for the switch on/off reading. value will tell you switch is good or you need to go after wiring.
  • Posted 1 Feb 2025 02:58
  • By Rocket_420
  • joined 1 Feb'25 - 3 messages
  • Alberta, Canada
Rocket_sine
Check the wiring by the top left inside the power unit. Compare it to a working one.
  • Posted 20 Oct 2022 03:09
  • By marcos_m
  • joined 25 Feb'19 - 114 messages
UN Forklift FD35T
UN Forklift FBR25NQC3
Tampa Florida, United States
May CapEx Index falls Washington, DC, United States
