Clark TM15 SCR Problem
Your help is needed ,the unit when turn on -press acc. pedal the contacts come in jumps hard and the contacts drop out.Found the 2rec conections was loose.replaced rec 2 same problem.Any cure?
  • Posted 23 Sep 2009 23:10
  • Discussion started by LOGIC
Thanks very much!! changed both rec's problem gone. In this industry you try to know everything but that's why other tec's who know more! thanks again.
  • Posted 31 Jan 2011 11:07
  • Reply by LOGIC
Yes the Ev100 are known for having rec 2 and rec 5 problems, and is always best to replace both of them together as John has stated.
I have also found sometimes after replacing rec 2 and 5 my problem has remained and found that sometimes even though its rare the snubbers that sit on top of the rec 1 assembly can also throw up errors which point towards the rec 2 and 5 circuit.
  • Posted 31 Jan 2011 07:44
  • Reply by elektrodrive
Whats mounted in your truck for controller EV 100 ore Cableform !!
Regards
John
  • Posted 30 Jan 2011 05:42
  • Reply by johngen
  • NB, Netherlands
Change always Rec2 And Rec 5 together
And this is the Number 910376
Its A heavy part Its modification
And look after your contactors Are the burned in !!!
These are have modification to
Regards
John
  • Posted 30 Jan 2011 05:39
  • Reply by johngen
  • NB, Netherlands
I have a similar problem when the drive is loaded for about 15 minutes, after turns driving the contactors, stands a little bit and flying forward again.
Details of the TM15 tm145 gef7095 7525.
Does anyone have good ideas?
  • Posted 14 Jan 2011 16:43
  • Reply by margo_k
  • Pärnumaa, Estonia
EV-100 system. Now I removed REC #2 measured it with VOM the good one and measured open.Installed -same fault.Manuels are a great tool to have. #5 WAS BAD!! measured VOM,it o.k.INSTALLED the unit worked? Going to buy a HANDY MAN. Measures and test SCR's AND Diodes and REC's for leaks. WHY? REC#5 Blows,dirt ,age,shorts or grounds
  • Posted 24 Sep 2009 22:30
  • Reply by LOGIC
hi, what control system does it have?
  • Posted 24 Sep 2009 14:19
  • Reply by roldann
  • nuevo leon, Mexico
had one of those two years ago had everybody involved cost me about two thousand dollars out of pocket changed lots of parts lost customer oh well good luck try to keep money in your own pocket lol
  • Posted 24 Sep 2009 10:16
  • Reply by towmotor
Those were very prone to bad connections at the card.
Try wedging a piece of cardboard between the card and the plug.
If thar solves the problem, then you'll have to repair the conection.
I believe that clark has a conector kit for it.
  • Posted 24 Sep 2009 02:39
  • Reply by mike_n
  • Alberta, Canada
Your Focus
edition #1233 - 5 June 2025
Stepping in for Angie Kay – who is taking a well-earned break from our editor’s desk – the story that catches my eye in this week's Forkliftaction News concerns the decision, by the California Air Resources Board, to drop its planned zero-emission forklift regulation... Continue reading
Elwell-Parker ESI500-36
Hyster
