CLARK C25CL DIRECTIONAL WIRING
FORWARD DROPS OUT, CHANGED COIL AND VALVE, SWAPPED FWD & REV PLUGS. LEADS TO WIRING PROBLEM UPSTREAM. NEED WIRING DIAGRAM OR ADVICE. THANK YOU
  • Posted 24 Apr 2012 03:37
  • By FORKLIFTMONKEY
  • joined 24 Apr'12 - 2 messages
Hello,
if you give me Your e-mail I will sent you the necessary information.
  • Posted 25 Apr 2012 00:49
  • By petko_t
  • joined 28 Sep'10 - 37 messages
  • Sofia, Bulgaria
p.troanski@abv.bg
thanks forkinlift, the s/n c232l-0155-9575
  • Posted 24 Apr 2012 06:47
  • By FORKLIFTMONKEY
Check the diodes which are at the bottom of the steering column in the loom, they did update them on later trucks, if you had a serial number I could check. Its quite a common fault.
  • Posted 24 Apr 2012 05:16
  • By forkinlift
  • joined 22 Jan'11 - 57 messages
  • Bucks, United Kingdom
