Check engine light
Have a check engine light. do not know how to clear or figure out what it is.
I do possess an OBD 2 scanner, but no way to connect.
Tried buying adapter cable with #3EA-55-36680. Dealer said it was not a good nember.
Help!!!!
  • Posted 28 Jul 2012 04:03
  • By howard_r
  • joined 28 Jul'12 - 9 messages
  • Missouri, United States
I had a Caterpillar today that had the check engine light on, no codes displayed. It was the 1805 code. The tail light bulb filament broke and swung over hitting the filament for the brake light inside the bulb. That put the check engine light on even though the lights were off and brake not being used. In other words, check engine light on, operator shuts it down, needed a new bulb.
  • Posted 15 Feb 2018 08:03
The Nissan-hitachi 23710 121 pin ECU's are notorious for INJECTOR failures.
The High Side drivers for the Coil and Low Side Drivers for the GAS mode Injectors are all on the same chip.
  • Posted 10 Jul 2015 04:21
  • By ECUengineer
  • joined 10 Jul'15 - 10 messages
Hi!
I have a problem with engine Nissan K21072686!It is seems like 2. and 3. piston doesnt work,I replaced control valve, cap an electronic, but again the 2. piston like it doesn't work???!!
If You have manual for this engine, it would be great!Just to see what can be wrong...i was talking with many mechanics , electronics ,but i didn't solved problem!
Best regards!
Dragan
  • Posted 25 Dec 2012 04:25
  • By marija_p
  • joined 27 Nov'10 - 33 messages
  • bosna i hercegovina, Bosnia And Herzegovina
mprolic@hotmail.com
there is a procedure to clear the code 1805
depress brake pedal
turn on key switch for 7 seconds
turn key off and release pedal.
should clear the code.
this will only work after repairs have been made to correct the problem. =)
  • Posted 1 Nov 2012 05:02
  • By DennisW
  • joined 10 Sep'09 - 21 messages
Howard,
The correct part number for the adaptor cable is 3EA-55-38680
  • Posted 30 Aug 2012 23:15
  • By Steveray
  • joined 30 Aug'12 - 2 messages
Howard call me Friday morning on my cell at 1-201-832-1606.So I can help you out betteron this.THANKS
ED
  • Posted 24 Aug 2012 12:48
  • By tool_king
  • joined 1 Jun'10 - 21 messages
  • New Jersey, United States
Did the pedal dance. Still amzed that they would put a brake switch blown fuse as a check engine light.
Bought a Nissan K21/25 manual to help diagnose the problem, or I would still be there.
Have got a OBD 2 scan tool with a standard automotive 16 pin male plug. The unit has a 12 pin female plug under the cup holder. Have to do a pin to pin maqtch up to connect. also the same for the dianostic plug 4 pin under the floorplate.
The interface cable is a dealer only item and thay prob ably wont sell to outsiders.
  • Posted 8 Aug 2012 21:00
  • By howard_r
We have had that one at the shop.Ecu does a check on system.How did you get the code out.Their are two ways to do it.One withe scan tool and other with fuel pedal.But the fuel pedal is a pain in the but.I like the tool better any way you can erace the history of stored codes with tool only and with pedel,
  • Posted 8 Aug 2012 00:13
  • By tool_king
Thank you.
Have also figured out the problem with the check engine light.
Got a code of 1805, brake switch open or shorted. Fuse F06 was blown for the brake lights.
Have no idea why they would put this in a malfunction category of a "Check Engine".
  • Posted 3 Aug 2012 20:56
  • By howard_r
That is the right number that comes with hand held tool to plug into the machine.I will double check the number on my tool tomorrow and let you know.
  • Posted 3 Aug 2012 12:01
  • By tool_king
Noblelift
