Check engine codes
This is a tier III truck with error codes 4-7-1, 7-1-7, 7-1-2 & 7-1-1. I know what the last 2 are but not sure about the first 2. Also, tried clearing the codes with the 10 presses of the accelerator pedal trick but no go. Got any ideas?
  • Posted 4 Jun 2010 02:43
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
Showing items 1 - 16 of 16 results.
Hi, sorry to bother ya I know this discussion is old but I was wondering if you still had the code list for clark forklifts... you would be a life saver
  • Posted 24 Oct 2020 06:21
  • By ToeTasTic
  • joined 24 Oct'20 - 2 messages
  • Louisiana, United States
Torrie Lacey
Could you send a copy of those codes to me? My email is [email address removed]
  • Posted 6 Dec 2018 14:48
  • By larry_c
  • joined 6 Dec'18 - 1 message
Hey Joe
sent email couple days ago.Turned out this customer has been leaving unit idling up to 6hrs per day,don't ask why,supposedly cheaper than replacing starters.
  • Posted 21 Dec 2010 12:31
  • By gary_r
  • joined 14 Dec'10 - 18 messages
  • British Columbia, Canada
Gary, my e-mail addy is in my profile (and that is a zero-one in there, not O-one...**** IT guys!). Send me an e-mail and I'll reply back to that as I can't fax out long distance here.
  • Posted 17 Dec 2010 05:20
  • By joe_d
Sorry Joe have checked everything seems correct.If you cannot email maybe you could fax it 604-941-9266.Again appreciate your help
  • Posted 17 Dec 2010 04:13
  • By gary_r
I sent an e-mail to the addy in your profile but it was booted back at me as undeliverable.
  • Posted 17 Dec 2010 02:02
  • By joe_d
Sent you email have received nothing yet.Email gives fx and email hope to receive something.Did you have anything on Doosan at all?
Thanks again Gary
  • Posted 16 Dec 2010 04:55
  • By gary_r
I sent you the list of codes that I have. Let me know if you don't get them.
  • Posted 15 Dec 2010 04:32
  • By joe_d
Thanks for responding sparky.We managed to get codes cleared and went through and fixed problem.However what we are looking for is a list of tier III codes if you have it.Have you had any experiance with doosan at all.It appears to be the same as the clark however cannot get codes to clear at present unit has a lot and we have tryed the key on 10 pedal pump in 5 sec codes will not clear.
anything you can help with would be appreciated
Gary
  • Posted 15 Dec 2010 03:13
  • By gary_r
What codes do you have???
  • Posted 14 Dec 2010 17:36
  • By sparky
  • joined 20 Sep'06 - 7 messages
Hey Joe,saw you requested a list of fault codes from Sparky,did you have any success in getting them.We are located in Vancouver BC ,if you did receive could you email me a copy have a Clark flashing up codes.My email is [email address removed] thanks in advance for any info you can supply
best of the season to you
  • Posted 14 Dec 2010 05:32
  • By gary_r
Ok, same unit, same codes. About once a month I get a check engine light with these same codes. Truck runs fine. 2 months ago, I swapped out the trim valve with new. Still got the codes. Checked grounds and all good. Also noticed this time that message something about PIN 25 popped up on the display a split second before the CHECK ENGINE MESSAGE. Since my original post I have been able to clear the codes with the peddle but not this time. I'm going to have to call the same tech out (only one at the local dealership with laptop and program for this truck). Could this problem be caused by the SECM?
  • Posted 9 Oct 2010 05:21
  • By joe_d
I put my e-mail address in my profile. Thanks alot Sparky. Some of these tier IIIs are driving me nuts.
  • Posted 17 Jun 2010 22:47
  • By joe_d
will need to email it as it is a image not text format
  • Posted 17 Jun 2010 06:46
  • Modified 17 Jun 2010 06:46 by poster
  • By sparky
Aint nothing a hammer can't fix
Thanks, Sparky. I ended up having a dealer tech out, who just cleared the codes with his laptop and they haven't come back. How many fault codes are there? Any way I can get a list?
  • Posted 17 Jun 2010 06:02
  • By joe_d
4-7-1 is ETC open fault- electronic throttle control driver has failed, onep or become disconnected
7-1-7 is fuel lock off valve fault-signal is open, sorted to ground / pos or faulty valve
Sounds like a poor earth or possibly damp in a connector
  • Posted 16 Jun 2010 08:01
  • By sparky
ROYPOW
Spencer/Sheldon/Sioux Rapids, IA, United States
UN Forklift FBR25NQC3
SMV (Konecranes) 4632CC5
December 03, 2025 - New Delhi, India
Lee Rushton Lee Rushton
