Caterpillar error code 35 and 36
Hi,
I have the following error codes at a Caterpillar GP 15 N from 2007, LPG:
-35
-36
The forklift runs slow when it has load on forks.
Anyone know what those codes means? And how do I delete those codes from display ?
Thank you !
  • Posted 17 Oct 2016 21:40
  • By bdio
  • joined 30 Sep'16 - 7 messages
  • Czech Republic
E32 is step1 overheat of cooling system
E36 is fuel pressure sensor fault
  • Posted 21 Oct 2016 22:29
I made a mistake:
The error codes are:
-32 not 35 and
-36
Thank you !
  • Posted 21 Oct 2016 21:00
  • By bdio
  • Czech Republic
Thank you ! I will check that and I will let you know what happened:)
  • Posted 21 Oct 2016 03:08
  • By bdio
  • Czech Republic
check your fuel injector and connections to it
also check the injector fuse
it probably needs to be replaced
you can try cleaning it but in my experience that does not hold up
  • Posted 17 Oct 2016 22:40
  • Modified 17 Oct 2016 22:41 by poster
Mitsubishi FGE35AT
Morooka MFD20
