Caterpillar EP20K fault 61
Hi there
Can anybody give me a bit of guidance about fault 61 on this truck.
Got no fwd/rev or hydraulics and my in line contactor won't close.
Checked the usual suspects ie fuses , handbrake and accelerator , seat swich and battery
Thanks
Kev
  • Posted 5 Nov 2013 06:53
  • By kevtwad
  • joined 5 Mar'11 - 76 messages
  • Northumberland, United Kingdom
Thanks very much to both of you.
Problem started when the keyswitch terminal snapped so it was only getting a feed down one of the wires which might have got it confused.
Kev
  • Posted 6 Nov 2013 06:58
  • By kevtwad
Problem: Traction Eeprom, Abnormality (61)
When this code is triggered all vehicle functions are inhibited, line contactor opened.
Faulty EEprom on traction logic board
How the error is triggered:
When logic software starts, first it reads the setup option data and the checksum data from the eeprom.
Software compares both data, when there is a difference code 61 is triggered.
You will need to get diagnostic tool and check the setup data and make sure it is set correctly.
I have seen in these truck the data gets corrupted when there is battery problem and has to be reset.
You will need the setup data to make sure you get it setup correctly for your model.
  • Posted 6 Nov 2013 00:26
Hello friend.
See your email.
Best regards, Laci
  • Posted 5 Nov 2013 16:20
  • By LACI
  • joined 24 May'09 - 195 messages
  • Serbia
Terberg RT223
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
