CAT VC60C Restoration, seeking help from experts around
Got one VC60C LPG forklift from auction and working on get it back to working state. The engine runs, lifts, weak drive torque. Seems have water overheat issue and engine oil pressure is not working. Going to start with standard testing like engine oil pressure test, compression pressure test etc. The engine oil seems be okay while hydraulic oil seems got water in it (cloudy).
It is continental f245 6 cylinders LPG with single speed power shift transmission, inching + brake.
This probably will be one long thread, appreciate any suggestions and thanks in advance.
Regards,
Daniel
  • Posted 19 Oct 2023 12:53
  • Modified 20 Oct 2023 04:50 by poster
  • By DANIEL
  • joined 19 Oct'23 - 3 messages
  • Washington, United States
Keep learning and be better, stay safe.
For people know this model, what are your recommendations for oils? Turns out the specs from that old manual are obsolete, most of them. Need help to find up to date alternatives.
  • Posted 30 Oct 2023 07:33
  • By DANIEL
Anyone know for VC60C, how could both transmission and hydraulic oil turns milky while engine oil stays fine. Need flush the system and fill with new oil, according to the manual I got, SAE 10W-30/40 is good for hydraulic and SAE 10 CD is good for transmission. What should I use to flush the system?
Thanks again and regards.
  • Posted 30 Oct 2023 06:05
  • By DANIEL
JLG G12-55A
Maxlion FG25
JLG G12-55A
Maxlion FG25
