Cat V50D resurrection
Hello, I am resurrecting an older Cat V50D serial # 3EC6078. I have managed to get this machine running, but am having trouble with the worn out carburator and cannot seem to find a rebuild kit or replacement. Unit has a Peugot XN1P engine that was converted to LPG, and I was wondering if anyone has ever replaced the carburator with a proper propane mixer / carb, and if so what make and model was used? Also wondering if someone could tell me the year of this machine by the serial number. Thanks in advance for any input.
  • Posted 3 Feb 2018 06:29
  • By shakymike
  • joined 3 Feb'18 - 3 messages
  • British Columbia, Canada
I am wondering if you had any success on getting a new carb. I am in the same boat now with a 1991 T50D.. Any advice or help would be appreciated.
  • Posted 10 Jan 2021 12:18
  • By Sean_Michael
  • joined 10 Jan'21 - 1 message
SM
try these hoof S100 S200 ,cant remember what I used on the truck I worked on. You can text me on 705 790 0266.
  • Posted 2 Mar 2018 00:00
  • By towmotor
  • joined 19 Feb'07 - 360 messages
Bolt pattern is 2-3/8" (60mm) center to center, inside bore is 1-1/4" (32mm). Original carb is a Solex F90714.
  • Posted 28 Feb 2018 08:53
  • By shakymike
Measure centre / centre of bolt pattern, I think the one I used was for a Toyota lift truck,send me the meaurments,i will figure something out.
  • Posted 28 Feb 2018 00:02
  • By towmotor
Shakymike,
The original governor as well as the carb was originally produced by Solex and has not been available for years now. There was a conversion kit to change it to Impco but the Hoof governor company went bankrupt and no one has produced the S100 governor that is needed to do the conversion to Impco. Try giving Century Fuel Products a call they may have a conversion kit using a different brand of governor. 734-728-0300
  • Posted 27 Feb 2018 22:41
  • Modified 27 Feb 2018 22:42 by poster
  • By Partsguy5
Sure no problem I will get the info for you in the morning ( Tuesday )
  • Posted 27 Feb 2018 11:44
  • By towmotor
Hi towmotor,
Any chance you could give me some more information on this velocity govenor? I cannot seem to find any parts place that can supply one to me. Any advice will be greatly appreciated.
Cheers.
  • Posted 27 Feb 2018 10:54
  • By shakymike
you can install a velocity governor under the carb
  • Posted 4 Feb 2018 06:32
  • By towmotor
It's a 1988
  • Posted 4 Feb 2018 03:52
  • By stam
Impco ca125 mixer. Model j regulator with electric lock off.
All I've seen is lpg ones. Don't know about governor.
I can get back with year if nobody else has by then.
  • Posted 3 Feb 2018 12:30
  • By stam
Airman ENCL045
Mobicon 2T
Airman ENCL045
Mobicon 2T
