Cat/ Nissan code E27
Hey Guys,
I have a customer with a Cat P5000, sn AT3502562. This code E27 just popped up. Any ideas? Machine still runs good.
  • Posted 20 Mar 2012 05:46
  • By Forkliftt
  • Louisiana, United States
Steve
steve at forkliftt dot com
Showing items 1 - 20 of 45 results.
what 2 cyls are down? center 2? how did you check spark? while running, disconnect each coil one at a time. If one coil makes no diff in idle, swap it with good coil. did it change? if not, remove all plugs first and do compression test. Head gasket between cyls 2, 3 commom. Bad coil or spark plgs can give this code.
  • Posted 14 Jan 2023 04:07
  • By Bluenose
  • joined 2 Apr'14 - 31 messages
  • Nova Scotia, Canada
Take me as i come, cause i can't stay long....
I have the famous E-27 code on a 2006 Nissan 30 forklift, MCPL01A15LV. Running Propane/LP. This lift has 600 hours. It doesn't get used much. Only to unload a truck maybe once or twice a week. It only runs for 5-10 mins most of the time. I've done a full tune up, new spark plugs, filters, fluids, etc. I replaced both crank and cam sensors. I did the pedal dance as directed above. This cleared the code and the fork lift ran decent for about 5 hours. On cold startup its idles up and down a bit but after its warmed up it runs fine, seems the throttle response is a bit sluggish to me though.
I've checked the coils and they are all working fine. It will only run on 2 cylinders. I did notice the plugs look a little browner in the 2 inner cylinders when i replaced them.
I'm starting to believe this E-27 code is a fuel issue. Can anybody chime in here please? I question if the regulator is gummed up or maybe the vaporizer? P.S i'm not a forklift tech. Just a mechanic trying to learn more about propane.
  • Posted 11 Jan 2023 09:30
  • By Aurorraborealis
  • joined 11 Jan'23 - 1 message
  • Utah, United States
I replaced the crankshaft sensor & still no start?
Any ideas mate?
  • Posted 3 Sep 2019 14:09
  • By Onsite
  • joined 5 Sep'18 - 16 messages
  • New South Wales, Australia
Lifting Services to new Heights
G'day all, I have a Nissan with a K21 that still won't start after changing both sensors, & spark plugs, it originally had a the error code 27, of which I placed the crankshaft sensor., clear the codes still won't start although it's trying to,
Any ideas will be much appreciated.
  • Posted 3 Sep 2019 14:07
  • By Onsite
New spark plugs have a cutback on the lower threads to keep carbon from building up. The aftermarket coils are a crap shoot 3 good 1 bad. All good or all bad.
  • Posted 15 Aug 2015 08:53
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
Thanks for the fast reply. I'm with ya as to aftermarket. I was kinda in a hurry and hoped I get lucky. You don't happen to have a good source or the part numbers?
I contacted the closest OEM supplier and they haven't responded.
  • Posted 13 Aug 2015 07:48
  • By KT7307
  • joined 13 Aug'15 - 2 messages
  • Missouri, United States
Dont buy atermarket parts.....use OEM ONLY!......you will regret it if you dont...
  • Posted 13 Aug 2015 07:41
  • By kevin_t
Dont ise aftermarket parts....buy the correct OEMmparts...you will regret it if you dont.
  • Posted 13 Aug 2015 07:40
  • By kevin_t
Greeting fellows-
Nissan 30 | Propane | Died, will not restart. Flashing Code 28 | Local parts store crossed crank sensor to aftermarket brand. However, the aftermarket "crank" sensor plug fit the cam sensor plug. So I put the aftermarket "crank" sensor in the cam sensor hole. Can I purchase a second "crank" sensor and alter the engine harness crank sensor plug to fit the aftermarket sensor? (LOL, I've no idea if this makes sense, however I'm hitting submit! Thx n advance
  • Posted 13 Aug 2015 07:21
  • By KT7307
Sweet!
  • Posted 22 Jan 2013 02:46
  • By Forkliftt
Steve
quick update guys.....plug gap was as bis a a pocket screw driver shaft.....replace plugs with OEM...and placed one coil pack....performed pedal dance to clear code....unit running like champ.....thanks alot guys.
  • Posted 22 Jan 2013 02:14
  • By hellcat
  • joined 19 Jan'13 - 4 messages
ALSO.....make sure you install OEM plugs dont use aftermarket or parts store plugs these engines dont like them to well.
  • Posted 19 Jan 2013 09:24
  • By kevin_t
these K21/K25 engines are COP style coils one coil per cylinder,to find what coil maybe giving you problems,run the engine and unplug three of the coils,these engine will lope/idle on one cylinder if it stays running then try the next coil and so on,if you find a coil that wont keep the engine loping/running replace it.
  • Posted 19 Jan 2013 09:18
  • By kevin_t
thanks guys.....appreciate the help.....will be going back to machine next week with 4 plugs and a coil pack.....will update then.
  • Posted 19 Jan 2013 09:12
  • By hellcat
cat has a bulletin out on this code
first thing they say to check before you go deep into diagnosis is the sparkplugs, if they are worn and do not fire correctly it can trigger this code.
They also say to check the coil packs, wiring associated with them also.
What happens when the plug gap gets wide or a coil pack fails the ecm tries to compensate the difference and causes the other components such as pos and phase sensors to go out of range. This is where the ecm thinks its a sensor issue... due to the inability to compensate.
Of course they go into alot of other scenario's that can create this code but those are the 2 most common issues that trigger an e-27.
As for all the dash lights flashing? kevin is correct, when the code hardsets in the ecm memory it goes into limp mode and hardsets the code. Only way it can be removed is through the clear cmd via the laptop program or possibly the 'pedal dance'.
Remember though, the pedal dance will not clear all codes, some of them have to be cleared with the diagnozer program.
  • Posted 19 Jan 2013 08:40
  • Modified 19 Jan 2013 08:41 by poster
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
The dash lights flashing indication that it is a hard active fault, I recommend changing. The cam and crank sensors at the same time, first check the wiring to both sensors to make sure is no broken wires at the connector they are both located just behind the fan the crank sensor is hard to see as it is lower and under the water pump.
  • Posted 19 Jan 2013 02:44
  • By kevin_t
I have a machine with same problem e-27, no one has talked about all the warning lights on the dash board flashing at the same time as presenting error code e-27. Flashing warning lights some other problem?
  • Posted 19 Jan 2013 00:40
  • By hellcat
I do think this is the first year model, 04 or 05, I can't remember without pulling up paperwork details. So if I understand what your saying, they have improved the durability in general of the wiring harness and the gauge or strength of the wiring? This would be good news as we are sending our lift in tomorrow to confirm it's diagnosis and likely replace the harness. I am tired of pouring money into labor to fix broken wires only to see them break again in a different location in the harness.
Thanks, for the feedback.
  • Posted 17 Jul 2012 08:22
  • By tileguy
  • joined 17 Jul'12 - 2 messages
  • Oklahoma, United States
tileguy,
that problem was more or less with the first year production models in that P & C series truck. Since then they have improved on the problems in the harnesses.
occasionally i still do see it once in a blue moon but not near as much as i did the first year those trucks came out.
after seeing the radical change they made in the materials in the harnesses, mainly the wire which is now less flexible and the core of the wire is harder and less strands , it just cant take the bends and vibration like the old type wire they used to use.
The engineer and purchasing agent that believed the suplier saying this wire was better need to have their nuuts cut off hehehe
this is just my opinion of course but it is what it is, i call it like i see it :o)
  • Posted 17 Jul 2012 07:55
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Thanks radon. Already fixed. Can't remember what:(. Getting old.....
  • Posted 17 Jul 2012 02:13
  • By Forkliftt
David Wells David Wells
Chief executive, Logistics UK
National business development manager, Roadpod
Senior vice president, PEAC Solutions
Board director, UKMHA
edition #1242 - 7 August 2025
In this week’s Forkliftaction News , we take a closer look at the main theme coming out of the recent CeMAT Australia event in Sydney: automation; why some are holding back and why not everyone will automate... Continue reading
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Terberg RT403
Yale Lift Truck Technologies
