CAT ( Mitsibushi ) M# P7000 S# AT14E - Brake Noise
The brakes squeal like a banshi when applied fwd and rev. Going to replace the shoes. My question has anyone had the same problem?? and did you use OEM or Aftermarket parts. Thanks
  • Posted 21 May 2010 01:13
  • By Prentice
are the shoes worn? this may be just a need to "burnish" and "arc in" the shoes due to rust in the drum. A lot of major brands of fork truck in this size range uses the same brake shoes and wheel brake setup, and all have a "cold brake squeal" some of the time, in part due to the hardness of the shoe's lining materials.
MCFA had some instructions about dragging the brakes until they smoked to get the shoes properly "burnished" and I have seen on forkliftaction some suggestions about adding baby powder to the inside of the brake drum through the adjuster window (this was on a like sized Toyota, but they all use the same Akibono (not willing to look up proper spelling) brake setup
  • Posted 21 May 2010 20:16
I also do this to recover the straps of the jaws when they are soaked with oil
  • Posted 21 May 2010 07:25
  • By AMartins
  • joined 8 May'10 - 107 messages
  • vila nova de gaia, Portugal
Hello. I usually take it up and gets better braking, I suspend a wheel with the lifting of the mast. and with the machine to work a little tightening up the brakes to heat until it begins to smoke, then do the other wheel the same. attention while it is hot but after just latch is ok. sorry to have responded in Portuguese
  • Posted 21 May 2010 07:19
  • By AMartins
ola. eu costumo tirar isso e até fica com melhor travagem; suspendo uma roda com o levantamento do mastro. e com a máquina a trabalhar aperto um pouco o travão de pé a aquecer até começar a deitar fumo, faço depois a outra roda o mesmo. atenção enquanto estiver quente trava pouco mas depois fica ok
  • Posted 21 May 2010 07:04
  • By AMartins
Taylor THC500L
TCM FHD105Z
