CAT LIFT TRUCK MODEL#P5000
THIS TRUCK WILL NOT START, TWO FAULT CODES ARE SHOWING UP P04 AND F04 THIS FAULT IS NO ECM COMMUNICATION ALL WIRES TO CONNECTORS ARE CONTINUOUS. COULD THE CONTROLLER BAD, COULD ANYONE SHED SOME LIGHT ON THIS.
  • Posted 24 Jun 2010 10:13
  • By vivian_roach
  • joined 1 Oct'09 - 11 messages
  • Freeport, Bahamas
failed P-04, F-04 mitsubishi FG25N AF17D000460
  • Posted 13 Nov 2012 23:28
  • By forklift_brasil
  • joined 27 Sep'12 - 55 messages
  • rio de janeiro, Brazil
tecmanuais@yahoo.com.br
skype:hyster.brasil
I have the same problem or similar Installed new relay box CORRDED bad did someone say fusable link ? or a 5 a fuse at the injector? I still need to go through and cleen all connects. key cycles only way to clear codes ? thx
  • Posted 3 Nov 2012 11:38
  • By jo_c
  • joined 3 Nov'12 - 9 messages
  • Arizona, United States
Yes Guys, truck is fix now. Broken wire from ECM to drive unit #39 for ECM CONNECTOR which is #9 on drive unit harness connector, PWM signal wire, repair and truck start and working fine. Thanks to everyone that share with me in the forum. Thanks alot.
  • Posted 9 Jul 2010 10:02
  • By vivian_roach
  • Freeport, Bahamas
The codes are gone now found corroded connection on relay box for EG1 relay but the truck is not starting still check supply from injector drive unit to injector connector no signal the drive unit getting all input signal bout not outputing to LPG injector this unit maybe bad will check wiring between control and drive unit because it should receive a pwm signal. Any other suggestio will help.
  • Posted 28 Jun 2010 13:01
  • By vivian_roach
  • Freeport, Bahamas
Swap the fusible link with a known good one or a new one, also check the 5amp fuse next to the fuel injector.
  • Posted 27 Jun 2010 03:27
  • By roadtech
almost all if these I have ran into (and this is about one of the 20 most common error codes these units pop up with) were either the relays (far most common), the connections to the relay box or the box itself not holding the connectors securely, a few were the dash itself.
It may be possible it is the controller itself, or a fuse, (hopefully you have checked all the fuses for a voltage drop first).
when you say the relays "checked out" can you describe further how you tested the relays? have you tried replacing all the relays from a "known good" unit?
  • Posted 26 Jun 2010 23:39
Edward all the relays were tested, all work well. I am testing all circuit for broken wires non was found so far. ECM are good could be damage connectors at ECM have to check. If any other suggestion, let me know
Thank you.
  • Posted 26 Jun 2010 11:27
  • By vivian_roach
  • Freeport, Bahamas
this can often be one of the relays in the blue relay box (my bet is the "main C" relay). there may also be a "spare" relay if this is not a dual fuel truck, that in the legend inside the relay box lid is labeled "fuel pump" and since there is no fuel pump for an LPG system, you can move the last relay (fuel pump) over to the main C position and fix this for very little effort or money. you can use the old relay as a sample to get a new one from an auto parts store if you can not get to a Mitsubishi or Caterpillar or Nissan forklift dealer. I 1/2 way think the PN from NAPA is a806, but could not promise that to be the case.
  • Posted 24 Jun 2010 20:05
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Crown SX3030TT4250
RAEDER-VOGEL
